Sorry I directed you to them. Maybe someone should direct them to this thread and the negative publicity they are receiving because they can't deliver. I'll google the pad and see what else I find when I get a minute.gwoods wrote:That car-stuff.com sight just sent me an email canceling my order... I placed the order over the phone on Wednesday? I hate it when companies can't keep track of their stock and will never order from them again.
I am trying to get pads from the place I bought the rotors from.
Jeff
Silicon based brake fluid can be used on practically any car. But you have to be able to get rid of all the glycol based fluid already in the system. ALL OF IT. The two will not mix at all.rn79870 wrote:One more thing you may wish to look into is brake fluid improvements. There was a lot of hoopla about silicone brake fluid (racing brake fluid) some years back. I don't know if this is compatible with Infiniti or not, but it is suppose to be heat resistant and provide a better feel. With your other improvements, it may help the brake feel. (I don't know that the QM really matters, but if you get back out on the track, it might)
Maybe some Infiniti tech can shed some light on whether silicone fluid is available for the G or not.
Depends. Newer lines will swell very little under pressure, but as it ages, it can start to make for a spongy feel. I'd say steel braided lines are a great upgrade as they should last longer and perform more consistently than a rubber brake line. But with a newer car, it might not be the first thing i rush out to upgrade...rn79870 wrote:Thanks C-Kwik, I also heard that changing to braided steel brake lines helps do away with brake sponginess. Again overkill for a street car, but if someone ran at the track frequently, do you think it would be worth it?
Here is some info that may pertain to yout hot-spotting. I'd explain it, but they do a real nice job of it and it saves me the typing:gwoods wrote:Brake fluid change and the engine decarbonizer is schedule for my 30k mile service in Mayish. I had IOS change the power steering fluid with the last oil change.
I had IOS service the transmission at 20k miles will do that again at 40k miles.
Probably service the diff at 35k miles
At 40k miles I will change the spark plugs myself, using OEM plugs at OEM gaps.
I have never felt brake fade in the G even working it out hard at the track. The front rotors hot spotted so I have a little vibration under hard braking but otherwise the brakes were great just worn out quickly!
I think the drilled/slotted rotors and ceramic/kelvar pads will solve my hot spotting problem. If they last a year I'll be happy.
I've been kicking around the thought of running dryer duct from the lower grill opening to the wheel well to help cool the front brakes but I'm concerned with how it would look.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
