I had a 91 LE that had ABS, but not an LSD, so it is possible. But honestly if that plug doesn't go to anything, then the diff is probably swapped and why would anyone swap in another open diff?
Jack the rear up under the differential. Turn one rear wheel. If the other wheel turns in the SAME direction, you have a LSD. If it turns the opposite direction, it's an open diff.
This method has often proven ineffective, the VLSD will act like an open diff if the viscous fluid is not hot. I tested it out on a J30, the wheels spun in opposing directions, but when I gutted the diff I found a VLSD.
You're both right. A Nissan R200V has a regular spider gear type open diff inside of it (albeit with 4 spider gears instead of 2) The only difference is that it has a viscous coupling within this assembly connecting the two output shafts (I've attached a link to a viscous coupling diagram below, which should help with the visualization) So when there is not a great difference in relative speed of the output shafts, the coupling will tend to let the wheels spin independently (or in opposite directions if the vehicle is jacked up with the trans in gear. This is how the diff lets you go around corners at normal speeds without completely locking the rear wheels together. However, when one wheel starts to slip under power, difference in the relative speed of the output shafts greatly increases, which creates friction in the viscous fluid and produces the locking force. Clutch type LSD's work the same way, they increase the clamping force on the clutch discs (aka the amount of lock) depending on the relative speeds of the output shafts. Clutch type's just do this a lot more quickly and effectively (read: "harshly')
Back to the VLSD, if you do the "jack up the rear end and spin the tires trick" with the car IN NEUTRAL, the wheels will both spin in the same direction. However, this is can also happen with an open diff with the trans in neutral. If it takes less force for the diff to just spin the un-engaged drive shaft than it does to spin the spider gears in the diff, then even with an open diff, your rear wheels will spin together as the driveshaft spins freely. The only way to be COMPLETELY sure that you have an LSD is to do the trick with the trans IN GEAR. When in gear, the engine provides a holding force on the rest of the driveline, so you know you're only testing the operation of the diff itself. Now when you turn the wheel, in the case of an open diff, the wheels will freely spin in opposite directions. If you have a VLSD they will also spin in opposite directions (because this diff still contains the spiders gears as I said before) but it will be very hard to turn the wheels at all, because even when cold, the viscous coupling still provides some locking force. This is the only surefire way of determining what type of diff you have without actually driving the car.
For you visual learners:
Here is a decent diagram of how a viscous coupling works
Hope this helps
