hey guys quick wire question
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
the main ground coming off the battery cable. the grounf other than the one that goes to the starter where does it connect / bolt too? i figured it was the passenger side top transmission bolt but im not sure let me know. plz reply with a pic or a good description. :facepalm:
robomatic12
Car: 1990 300ZX TT
Its connected in two places, on the back of the engine block and onto one of the transmission bolts.
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
any more info its a 1990 na with a 1995 na vg30de the ground cable coming off the battery has a connector for the starter and further up another ring connector looks like it bolts up to transmission want to make sure though
marty1mc
Car: 1990 Nissan 300ZX TT - Z owner since 2003
The ground connects at two places, but they are on the top right bolt of the transmission where it mounts engine (battery side of the transmission). The second one mounts to the firewall. If you look at the battery, it should be just above it about an inch below the top of the firewall and toward the driver's side.
zfactoryftw
Car: 1992 s13 coupe
1993 s13 vert
1991 mazda b2200
2004 jeep liberty
thanks guys
