sooner4x4 »
https://forums.nicoclub.com/sooner4x4-u71453.html
Wed Mar 09, 2011 8:25 pm
Hey Bobsyouruncle, did you ever get the 2007 Versa? My Versa is an 07 and has been a pretty decent car. As another mentioned, try to get some idea of the service history. If you can't determine when the transmission fluid was last changed and the coolant flushed, you should consider doing that after getting it. Make sure the correct Nissan CVT transmission fluid is used. The air filter and cabin filter are super easy to replace. Check the brakes and change the oil, then drive it for many years. I have no idea on the value of used cars these days, can't help you there. Plenty of resources out there to check typical used car prices.
