damm, smart idea . Now I'm going to trace a pulley on a paper and mark it before drilling . Thanks for the idea bro.dash wrote:I remmeber drawing the pulley and marking the magnet placement, life size, using CAD.... for my neighbour years ago
Fit on a 8.5 x 11 sheet. All he had to do was cut out and overlay it on the crank pulley
It didn't take him long to go from never tuning, to having that stock motor pegging the 30psi gauge
Car was skating all over the road, even 2 long tire marks in 4th - lol
Did the job for what it was
He's all AEM now, in a 2JZ/74mm S14. He'll never get dash back in that dam car again. Ever - lol
thanksfloat_6969 wrote:The most important part, IMHO, is making sure the two trigger magnets are exactly opposite, or 180°apart from each other. If the home signal is off a little, it won't make any difference, and if the three magnets aren't exactly oriented the correct way, you can adjust the magnet position to accommodate.
Well I'll be gosh darned! It really is "simple"!float_6969 wrote:Base ignition timing with an SDS defaults to 10°BTDC. There are no trigger or coil firing edges with an SDS. It doesn't use a trigger wheel or the optical disc in the CAS. There are magnets mounted in the crank pulley and a Hall sensor to detect them.
One way or the other we're looking to see how the engine responds to changes in the mixture and there's no hard or fast rule with what AFR will make it fire up the easiest. Just give it what it wants.My Innovate is pretty good about telling me the cranking AFR's. There's about a 1 second delay before the exhaust gasses hit the sensor from the time I start cranking.
Depends on his placement of the hall sensor and the magnets, really.I agree about the base timing. On the SDS there is a parameter called "Magnet Position". It is adjusted until the measured timing matches the programmed timing. Usually though, it's only off a few degree's, and the engine will still start.
Indeed!float_6969 wrote:The installlation of the magnets in the crank pulley and the mounting location of the Hall Sensor is the most important part of the SDS installation. If any of that is off or wrong, it directly effects the timing, and there's not a lot of room for adjustment from a tuning standpoint.
If he can get a timing light on it while it's cranking and we can see where is timing actually is versus where it's programmed to be, that is going to tell us most of what we need to know regarding the Hall sensor/magnet location variable. If it's pretty close, then he's done that part of the installation correctly and it has to be a fueling issue, which is easy to deal with.
Rpm timing valve from 500-1500 are 10*. Vac and psi I have to check .float_6969 wrote:Base ignition timing with an SDS defaults to 10°BTDC. There are no trigger or coil firing edges with an SDS. It doesn't use a trigger wheel or the optical disc in the CAS. There are magnets mounted in the crank pulley and a Hall sensor to detect them.
I did just think of something though, is the OP running gasoline, or ethanol? Also, what are your RPM timing values from 500-1500? Any timing advance or retard between full vac and 0psi?
