Lol yea I'm just going to enjoy it for while till next year. But is there anything else I need to know ?boost_boy wrote:A 1000cc is more than enough, but they would be great to have "Now" if you're going to upgrade soon to the bigger turbocharger. If you are at least 6 months + away from upgrading the snail, leave the 450s in and enjoy. Your setup sounds fun
I have 1000cc Bosch from my rx7 its low impadace. It's was in the ca18 before I swapped out to 450cc ,and the car idle fine with 1000cc. But I still think is a little too much for now that's why I swapped them 450cc. But I really wanna see 15psi and up on this motor before swapping the other motor in hehe.Buddyworm wrote:If he's talking 1000cc Bosch EV14 types he'll be fine. They're stable at the pulsewidths you'll see with a CA at idle.
EV1 tech on the other hand...
Lol just wanted to be safe and start at low psi . But I'll pm you once I write everything down. Thanks man.boost_boy wrote:15 psi? Why can't you get 15 psi now? I run on 15 psi with the boost controller off and only using standard wastegate spring pressure. Man, go boost the darn thing. I don't think you can hurt much with your current set-up, but make sure you parameters are not out of whack for those 450s. If you want to, you can PM your parameters and I can tell you "YAY or NAY".
To dash you listen, yes.dash wrote:glad to c u enjoying it. The little turd can scoot
don't get too carried away with timing. Feels so good..... up until then the condom bursts
what u using for knock monitoring ?
Lmao.I'm not playing with the timing that much I'm still only playing with the af for now, till the dyno. For knock I'm just looking at the sds knock screen while my girl do some pulls and I'll adjust what is needed.dash wrote:glad to c u enjoying it. The little turd can scoot
I'm kinda still scared to go to 15psi on minds even tho I have a gt2871r but also stockblock, but building another one on the side. It's hard to find a tuner that plays with the sds in the northeastern area. Most of them always tell me it's better if i get a apexi fc,Aem or different brand.But I'm happy with sds and why spend more money if your car is running fine and just need to be on the dyno more.Buddyworm wrote:To dash you listen, yes.dash wrote:glad to c u enjoying it. The little turd can scoot
For reference: My shortblock is stock with a 2mm thick MLS headgasket, TD06-20G. On 15psi I'm at 16* advance for most of the revband. Engine doesn't want any more than that.
No,i love the sds it's easy to wire up and tune, even tho I'm still new to tuning, but the system is really easy to understand.The reason why I wanna go on the dyno is to see the max timing I can go on the car. Me and my lady been with each other for 8 years and your the 20th person that said that this week lol, soon this year.dash wrote:When a buddy 'whined' to sds about the lack of bells & whistles, polite reply was, "sounds like you've outgrown our system"
He got his wish; AEM, and a car that's completely useless on the street. Ridiculous power
I know a few cats still running sds from way back.
Bottom line - does the job for what they intended = proper tune fun street car
Some can break traction in 3rd or make more power than u can use on the street really
I can remember one or two of em mentioning magnets flying out at 1st, and the programmer going bad
They are all diy types that quickly learned to tune.... and never been on a dyno
.....and that's without the luxury of girl like yours Had to settle for some boxhead. Marry her
boost_boy wrote:Check your PMs. I'll shoot you my number and I can assist you from here. I do believe your turbo will run out of puff by the time I'm done with you
