Hey guys, need a little help with my sds efi em3
Sc0oByDo0RaCeR
Car: 240sx s13- ca18det.
Lol, I didn't knew they sold those or I can make one.
float_6969
Any progress?
boost_boy
I guarantee you it's the placement of your magnets. If it backfires, then you more than likely put on of them in backwards. If it cranks and attempts to run, but does not start, means your values are all over the place. The problem is, you don't have much room for error when placing these magnets onto your pulley. If you struggle to get this right and have run out of options, let me know as I've done this on the CA probably more than anyone and I know what not to do. But get back with the forum on your progress.
Sc0oByDo0RaCeR
Sorry guys I been busy and had time to mess with it today and it was the megnets , one of them at the 180* was put the wrong way. Stupid me :facepalm: . So if anybody got a crank pulley for sale lmk thanks guys.
Sc0oByDo0RaCeR
is there a way that I can take the magnets out or is it better that I just get another crank pulley?
Sc0oByDo0RaCeR
So I just paid for a crank pulley and magnets today and waiting for it to be shipped here, once it do I'll report back.
float_6969
Sorry, I just saw this. Yes you "can" sort of get them out, but you basically had to smash it with a hammer, and then spend the next 80million hours of your life digging all of the pieces out. It's awful. Assuming the epoxy set up properly, LOL! If you didn't see my thread, I just had a magnet fall out. The epoxy didn't cure properly and so it never hardened.
The new crank pulley and magnets are a WAY better way to go.
Sc0oByDo0RaCeR
Lol I'll try it out on the old crank since the new crank came in and I'm just waiting on the magnets , I order 9 of them since they were .23 cent from a website that one of the workers from sds gave me shhh I didn't say that lol. But it's coming in 3days I can't wait. I wanna thanks everybody for helping. Thanks guy I will keep everybody updated.
Sc0oByDo0RaCeR
this is the website for the magnets, if you guys are looking for extras. kjmagnetics.com magnets are D23.
Sc0oByDo0RaCeR
Just an update , I just put the magnets in and waiting for it to dry up. I'm going to wait a few hours just to make sure it that thing is fully harden.
Sc0oByDo0RaCeR
Hey guys
THE CAR STARTED!!!!!!!!!!! . I waited till the magnets dryed up and slap it on and turn the key, boom started right up. I'm so f-ing happy . I then put the timing gun on the crank at set it at 10* and went back to the sds handheld and set it to 15* from 500-3000rpm .Thanks guys for helping with all the info.
float_6969
How far did you have to adjust the magnet position to get the base timing to line up? Regardless, I'm happy to hear you're up and running!
Sc0oByDo0RaCeR
It's set at 88 on the magnets position . The things revs up with no problems . I can't wait to take it to the track on a test and tune night, to fine tune it. But I also have to finish cleaning up the harness.
float_6969
88 seems high. You had to change it that much to get the timing to match? I've never had to have it set higher than 85.
Sc0oByDo0RaCeR
I hope not. But the car starts up and rev up with no problem. What's the safest timing map # I should run? I'm basically using what was with the system.
float_6969
Is it on pump gas? How much boost are you running?
Sc0oByDo0RaCeR
93 pump gas at 10psi for now.
float_6969
8 port head, or 4 port? IIRC, the base timing on the 8 port is actually 10°, and the 15° number that we're used to seeing in the FSM is for the 4 port head. I would run base timing up to about 1750. Then at 2k, I added 2°/250rpm until I hit 27°. At about 7-8psi, I would start pulling 1°of timing per psi of boost. That a pretty safe timing setup. It will leave some power on the table, but shouldn't cause any issues with detonation.
Sc0oByDo0RaCeR
This is my rpm timing
500 to 1000-15
1250-16
1500-20
1750-24
2000-30
2250-34
2500-36
2750-38
3000-38
3250-38
3500-35
3750-35
4000-34
4250-34
4500 to 7500-32
It's a 8 port so I'll change it back to 10* .
float_6969
38 is too much for this engine, especially the 8 port head. When the power vales are closed at low RPMs, the burn speed in the combustion chamber is fast enough that a lot of ignition advance isn't needed.
Sc0oByDo0RaCeR
So I should do 32 from 2750-7500rpm?
Sc0oByDo0RaCeR
im really just trying to get a safe rpm timing, before I take it for a drive just to be safe.
Sc0oByDo0RaCeR
Would his be safe Or should I do 27* from 2500 to 7500?
500 to 1000-10*
1250-12
1500-13
1750-16
2000-20
2250-24
2500-27
2750 to 7500-32.
float_6969
I'd do 30 from 2750 on up. Any plans to get it on a dyno?
Sc0oByDo0RaCeR
500 to 1000-10*
1250-12
1500-14
1750-16
2000-20
2250-22
2500-24
2750 to 7500-30
I'm going to do some pulls with the wastegate off so it's like a Na motor so that I can have a good fuel and timing, once it is all set I'll start with a low psi pull and make sure that the wideband never see over 11.5 and if it do I'll catch it before it's leans out and fix it and turn up the boost and repeat it. Also I will retard it by 2* so I can drive the car and be set for now and later on do 10* retard to be at 14psi .
Sc0oByDo0RaCeR
float_6969 wrote:I'd do 30 from 2750 on up. Any plans to get it on a dyno?
I wish there was tuners in the northeastern that's mess with sds . But later on I will.
boost_boy
Glad to hear you got it running ;). I'm going to be lazy and not go back through this thread, but ask, what size injectors are you using? I can give you some idea some idea of where you're at tuning wise. And also, what map sensor are you running? 2,3,3.5 or 5 bar?
Sc0oByDo0RaCeR
boost_boy wrote:Glad to hear you got it running ;). I'm going to be lazy and not go back through this thread, but ask, what size injectors are you using? I can give you some idea some idea of where you're at tuning wise. And also, what map sensor are you running? 2,3,3.5 or 5 bar?
I got 450cc and 1000cc , I'm running 3 bar .
Sc0oByDo0RaCeR
My set up right now on the ca18
In/ex 248/248 cams swap with goleby cam gear.
450cc in them, but going to put 1000cc later.
Fmic
Gt2871r
3in catback
3 bar
Sds em3 with upgrade chip
Aem wideband
Aero fpr
I'm going to upgrade to a gtx30 later. also builting another block on the side.
float_6969
1000cc injectors on gasoline with this system is probably beyond what it's capable of handling well. It will run, but you're going to have a lot of variance in the AFR's. It's fine running the 450's and the gt2871 though.
