skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.html
Thu Jun 29, 2006 12:03 pm
grey wire is only on the rb25, the 20 has power to the injectors individually from the ecu.
First Id try to switch your fuel lines (again), if that doesnt work, replace your fuel filter. If that doesnt work, mark your CAS and remove it, and with the key ON spin the gear inside by hand. You should hear your injectors clicking if the CAS is good.
The dry return fuel line has me thinking its definately switched fuel lines. I know you tried it once, but if its getting fuel to the rail, it will turn over (as long as everything else is as you described.
