Hey Guys... i need a little help.
GnarKiller
My situation: Just got done swaping my engine in my 1995 240 se and i need help BAD. i have all my connections hooked up except one where i can not find the other end. The engine starts up okay but after a while my air bag light will flash and and my radio cut off and my lights dim and sometimes cut off too. if i keep it going like this my engine will bog then stall. If i try to start it back up it usually wont start. im think that my problem is my alternator but im not sure i need some help guys anything will be great. another thing is when i start to drive it usually wont go over 3,000 rpm.
Thanks alot,Zach
quiksilvia
Car: 95 s14 se
sr20 swap? sounds like alt, did u hook it up?
GnarKiller
Nope just a new KA, im in the process of rebuilding my other KA and preping for KA-T (the reason i swaped in the first place is because in the older KA i spun a rod bearing.
I believe the Alt. is hooked up correctly i will check though (whats all supposed to be hooked up to it?0
Thanks,Zach
quiksilvia
Car: 95 s14 se
on the sr alt, there is a ground, and 2 other connections
NISTECH
check your bulk connectors near the battery are they all connected? also check all your fuses.
GnarKiller
Thank you guys the problem is now fixed that one part of the harness was the part that connected to the alt. and starts up just fine now. especially with my injen intake and hks hiper exhuast and i just bought today a red top optima battery. i love my car!
Thanks a whole lot (yous guys are great)Zach
