lame fake ecu wrote: ECU chip replacement has rapidly become the easiest, and most efficient modification available to increase horsepower power and torque.
Designed for use on stage 3 cars (high performance air filter, boost jets, cat-back exhaust are a pre-requisite). This ECU upgrade removes the speed limiter, raise the rev-limiter to 7300 rpm, and adjust the timing & fuel maps for up to 17 PSI of boost!
Prevents detonation when running higher boost. Allows a better air/fuel mixture to be burned with the higher boost. Also make sure your base timing is set at 15 degrees.
Your car can do over 400-rear wheel horse power with this ECU chip upgrade.
Taking full advantage of 91+ octane fuel, Performance chips unleash more power by reprogramming the fuel mixture and ignition timing parameters of the engine management system.
Well, considering these claims will actually blow your motor eventually if you still have stock injectors (unless you want to run at 100% duty cycle forever). It is "feasable", but doing over 400WHP with only that is silly.
