alvco001 »
https://forums.nicoclub.com/alvco001-u11808.html
Sun Dec 14, 2003 8:19 pm
just purchased an 71 510. I drove the car , seemed fine. It has been lowered has fron strut camber plates. The camber out back seems to be a neg 1.5 apprx.. Also has a rear swaybar.After purchasung the car I took it out for a good test moto. After about 20 min of pushing the car a little, something got hot or stuck or was sticking in the braking system. The brake pedal got pumped up and something felt like it was dragging. Dont know what, I jacked up the car and found some resistance when I manually tried to rotate the rim, both sides. Same when I removed the rims and manually tried to rotate the IRS. Thanx in advance for the help. Tim:ylsuper
