gaehrings13 »
https://forums.nicoclub.com/gaehrings13-u19305.html
Fri Sep 15, 2006 6:09 pm
Well i've tried it all thermostat, metal radiator, changed fans, and i'm pretty sure i bleed it correctly.....
I'm starting to think its the headgasket... ugh I don't know im tired now and thinking it can only be the worst.. Well read the story please! and tell me what you think.....
Well the car kept overheating and i couldn't figure out what it is, and the damn radiator blew up.... So I replaced it with a CSF metal one. Put water in and bleed the system. I still get the same problem and my autometer gauge starts to get around 210 degrees and when i put the AC on it starts to go over it and the AC starts to go away. So i went to look for a stronger fan and a friend of mine had a stock honda fan, wich i knew are very strong. I use to use my stock honda fans on my turboed Ls integra...
All of this is without a thermostat....^^^^^
When i was putting the honda fan i noticed that on one of the larger fans that i had was getting hot on the motor.... So i decided to scrap that one and use the honda one and the smaller one.... Tried it and it started staying around 180 200 degrees.
Well today I went to hang out with a friend and it starting doing the same crap.... So he said put a thermostat back again and it should work better. Tried this and it was staying cooler for a little long but eventually it will heat up again.. Right now it sits at around 210 if i turn on the heater it will slowly get cooler.. But man as soon as the AC goes on the damn temperature starts rising quick it gets to 212 degrees to 215.....
I checked the oil it doesn't look milky the engine isn't throwing any white smoke the coolant is very very clean... also it doesn't look like any compression is getting in the water, and it isn't leaking water from anywhere at all, especially from the sides of the head lol...
new thermostatnew metal radiatornew radiator capold hosesone honda fanone autozone special fanwater mixed with antifreeze
Lol now i need to tell you how i got the motor i have now.The engine was free and was suppose to be perfect thats what my friends said.... I put it in and it had a blown headgasket
No problem I change the headgasket and put everything the way it was suppose to be because a retard put that engine back together... So if you guys can help me I will appreciate it, I really wanna be sure it is the headgasket before i take anything apart.
