[quote=" eLEmEnT [/quote]Quote »I came to you guys to see if its a good choice, since I really wouldnt know.[/quote]This is the damn RB forum, what do you think we're gonna tell you? =P I would definitely say it's a good choice. The motor's a LOT of fun (I can tell you this after only driving my car once, right now it's sidelined with overheating problems), absolutely screams at 7000-7500RPM; SR20s won't do that without throwing a rocker arm off :pface Great pull up top, really nice sound, great motor overall. But I have a DISCLAIMER, and that is not to even consider this swap unless you have a lot of patience. Take the amount of time you expect the swap to take you, multiply it by 3, add 10 and that's about how much time it's actually going to take (add some money to your figures while you're at it, too). I've been working on my car on and off since September (engine, suspension, brakes, everything) and it's finally just about done.
Quote »1. What are the horsepower/tourque rating on the engine? The guy told me around 250hp, is that right?[/quote]That's a lie. RB25DET will give you 250HP stock, RB20 is 220.
Quote »2. This may sound like a wierd question.. but I was just reading about the rb20 swap and some guy said you wouldnt have power steering afterwards. That sort of worries me. Dont the swap typically include power steering too?[/quote]Another lie. Do a little bending of the steering lines, throw out the HICAS bull$h|t, plug and castrate the steering pump and voila, power steering. Search this forum for it, you'll find all sorts of detailed info on it.
Quote »3. The price after installation was around $2700, is that reasonable? For a professionally done job with a warranty.[/quote]If that's everything you need (i.e. you hand them your car and $2700, they hand it back with a running RB20DET and a warranty), then I'd say it's worth it if you don't want to get your hands dirty. I will tell you one thing: if you want to tune this car and do a lot with it and really get into it yourself, I recommend doing the swap yourself, maybe with a couple friends helping you out. You will learn SO much; I went into this swap knowing nothing except basic stuff, and now I feel like I can do anything with a car. Great learning experience, and there's plenty of info here to get you through it without serious incident.
Quote »4. Also, im not intrested in drifting, but i dont want my car to handle like ***. Ive reada lot about how the weight displacement is thrown off a bit by this engine because it sits so far forward.. is it really noticeable if you arent out there trying to drift?[/quote]SR20DET drivetrain weighs 493 pounds. RB25DET drivetrain weighs 720 pounds. The RB25 has .5 extra liters over the RB20 and a MUCH beefier transmission; I would estimate the RB20DET drivetrain to be right about 630 pounds or so. ~130 extra pounds up front?? Hell, extend your cables, stick the battery in the trunk, and you've practically made up for the uneven distribution already.
Quote »Thanks in advance guys [/quote]
NP
Normally I would be an a$$ and say SEARCH (which you should, it's extremely helpful), but I felt like typing an essay.
