ca18detsilvia »
https://forums.nicoclub.com/ca18detsilvia-u1467.html
Wed Feb 02, 2005 2:11 pm
i have a problem, i'm worked so much on it and thought about it so much that i'm out of ideas and stressed out. to start with i put a new turbo on my car about 3 weeks ago, a power enterprise pe1420, the next week i took it to the dyno and tuned it, i put a mines ECU in that i had laying around and it took a while to get things right, that ecu really advances timing, but we got the a/f's looking good below 5k after doing a few runs and pulling back timing to get rid of alittle detonation, got that fixed and did a power pull and the clutch started to slip so we took it off the dyno and i drove it home, i didnt' touch it till a week later when i drove it to classes, it started to cut out on me and felt like it lost power, below 3k it sputters and runs like crap and wont idle like the maf is out, i put a new maf on it and it did the same thing, someone told me it may be a vacume leak but according to my boost gage it was fine, but i took all the vacume lines and hoses off and replaced them just to be sure, nothing, i had a fuel pump problem before and it acted sorta the same so i checked the pump and its fine, then i thought the bov was stuck open so i took it apart cleaned and oiled it and still the same thing . i have a z32 maf and super afc, the maf settings on the super afc are 2in 7out, but if i turn the out setting to 8, it idels fine and can drive ok, when you get on it, it makes full boost but it feels like it isn't going anywhere, its not pulling but revs fine. i really am stumped here, if anyone can suggest anything please do i'm on my last straw w/ this. it ran perfect on the way home from teh dyno and i idn't drive it till a week later when it suddonly started to act up
