HEY DEVIOUS AND PANDA
BigLeeRoy EngineBuilda
i finally won these on ebay. so the project starts, i will keep yall posted. the megasquirt goes on order in 2 weeks also. i am gonna buy the box already built, but will build my own wiring harness.
http://cgi.ebay.com/ebaymotors...%3AIT
deviousKA
Car: 90 240sx NA /72 Datsun 510 NA /86 corolla GTS NA
Good deal BigLeeRoy, throttles look good. Im using 2002 750's which are the same.
You got the de right, or you a single slamma? Take lots of pics and stuff when your designing/building . With all the different combinations of parts and design, things get interesting
PandaS14
Car: S14
Sweet.
Good to see more people getting into this. It's not as hard as people think it is, however it takes 10x the time people think it does.
I second what Devious said about the pics/documenting.
Oh and if you need any help, my aim is PandaAkS14
Cheers.
oh no i got a ka E devious. hey thanks panda. my roommate is hounding me about the megasquirt system. he is gonna use it on his 2jz in his cressida and our other friend is gonna use it in his truck we did a twin cam swap in. they built there systems and the stimulator already. i am just buyin the box and harness. i am so glad to be back in the states and actually do a project like this. i plan on drifting this car with this setup.
InsanityInc
PandaS14 wrote:Sweet.
Cheers.
Really what we need is a good intake manifold that's being mass-produced, to get rid of the truck manifold we have. I was going to get a guy to do it, but he's been dragging *** for so long I don't know if he's even doing anything.
PandaS14
Car: S14
Truck mani? Are you referring to the long runners? Well in any case it's not a truck mani because the ka trucks had different manis than 240's.
sorry, I'm just so sick of "KA's are truck motors", and the like.
anywho, there is a mani for kaE's, it's the nismo one. then you just get ITB's made to bolt onto carbeurator manifolds. Forget which carbs the Nismo mani is made for.
yeah, but for kaDE there is nothing.
well they are here. THEY ARE SO TINY!!!!!!!!!!!!! WTF!!!!!!!!! oh well. now the fun begins. orderin megasquirt on friday
will be postin up more pics as it progresses. but i wanna try and do a write up for it once its all said and done. this is gonna be a long process but my end result is a turbo ka with individual throttle bodies. the motor is already .020 over with hybrid ka pistons and i ported a head for it i need to install. but here are the pics of it IN MY POSSESSION MUAHAHAHAHAHA!!!!!!!!!
deviousKA
Lookin good Leeroy, what velocity stacks are you planning to run?
oh, and hows your manifold coming along?
Checkered-Member
Car: 1998 Nissan Altima (modded)
2003 Audi A6 2.7T (stock)
Question:
How are you going to meter the air going into the engine?
i sent a diagram i drew up to a friend thats gonna get my manifold welded, and devious told me about another manifold to use. i will be making 2 manifolds for this. i will be using a map sensor. megasquirt runs a map sensor. people have used maf sensors before though.
dfw240_EE
Car: 1992 240SX
Good luck getting the Megasquirt to run. I have read through their manual. Seems you need to put in some time to get it just right, but I like the reported results.
InsanityInc
PandaS14 wrote:Truck mani? Are you referring to the long runners? Well in any case it's not a truck mani because the ka trucks had different manis than 240's.
The long runners and secondary butterfly valves, both designed to improve low-end torque, and both restrict high-end power.
Quote »sorry, I'm just so sick of "KA's are truck motors", and the like.[/quote]Hate to break it to ya, but it's the truth. 89mm bore and 96mm stroke with long runners and secondary butterflies (the truck manifolds are different, but not that much different, still have the same design philosophy). It's not a truck motor because it came in trucks, it's a truck motor because of how the engine is designed.
dfw240_EE
Car: 1992 240SX
How about "truck-like" design then?
PandaS14
Car: S14
I'd just call it an oversquare I4 but we're splitting hairs here...
