Hey dee... non CA related Question...
Liquid_Neon
Car: 2000 Toyota Echo, 1988 Pulsar NX SE Turbo
I think i recall you once mentioning you knew Hyundai's... is that true? Im searching other forums but i thought id ask here just once... need info on a crank sensor on a '04 sonata 2.4L
boost_boy
Liquid_Neon wrote:I think i recall you once mentioning you knew Hyundai's... is that true? Im searching other forums but i thought id ask here just once... need info on a crank sensor on a '04 sonata 2.4L
What you need to know, man? I'll help if I can..........
Dee
Liquid_Neon
well i was trying to figure out just how much of a pain in the arse that crank position sensor is... but i finally found some info.
Who puts a sensor BEHIND the timeing belt... im never buying a hyundai!
I thought my VW was bad... hahaha
thank you dee, your the man for offering help no matter what!!
