drifter_for_life06 wrote:are all KA ECU's intercahngeable? even SOHC?
Do you mean from the same years or across the board?
'89-'90 are same. '91-'94 are the same (except '94 are all AT, but that can work on MT). '95s are the bastard child (only S14 OBD1). Not positive but think '96-'98s are all the same.
But you can't swap SOHC for DOHC (8bit processor vs 16bit processor). It is probably possible to do something between S13 DOHCs and '95s. And if you use the wiring harness from that year you should be able to hook that same year to it. Just some of the things on the engine might have to be changed (connectors, wires, etc). Think I just confused myself, hope it helped a little.
