Loveless wrote:there may be some lag BUT, with the turbo constantly cooled by air that goes through under the car, it probbaly make up for it if not better performance from the cooler turnbo
Running the turbo at a cooler temperature will do little for performance. Only a very small percentage of heat from the turbo is transferred into the charge air. With the amount of air flowing through a turbo under boost and the velocity, there is little dwell time for the turbo to actually put any significant amount of heat into the charge. Almost all of the heat in charge air is created by the compression of the air during boost. This does not change depending on where the turbo is mounted.
My take on this? It is a workable alternative. It's quite a bit less than ideal as the exhaust temperature will be much lower than it would in a more traditional set-up. The biggest drawback I see stems from this. As exhaust gases cool, so does the volume of air. You can certainly resize the turbine to compensate but the ideal compressor match does not change. Turbo manufacturers generally try to match turbine and compressor efficiency points to compliment each other. Having to size down the turbine will likely change this and cause the peak efficiencies of each to occur at different places. When looking for the quickest response and least backpressure from a given turbo, you want both the turbine and compressor efficiencies to line up well. With a rear mounted set-up like this, you'll end up with something more like a T3/T4 hybrid set-up as far as efficiency is concerned(T3/T4 are great versatile turbo set-ups, but if your quest is a ultra high HP turbo, it is not ideal because of the difference in the compressor and turbine efficiency points. But in this case, since a lot of heat energy is lost, you'll have to make up for it by running a higher pressure differential across the turbine. This basically means the motor will see more backpressure which is a parasitic loss. If you look at their power gains as well, you'll see this. A way to estimate a power increase in a motor is to multiply the power output by the pressure ratio increase. This vehicle is fairly close. However it is slightly lower than the calculated number at both the 5 and 7 psi levels. AS a comparison, 7 psi on a KA would net 190WHP from 127WHP with 7 psi. The reality is that most KA's running 7 psi are putting out closer to 220-230WHP at 7 psi.
I also find it highly suspect that this company still claims an increase in fuel economy. The turbo is in fact a restriction in the exhaust. Especially, off boost, where the turbo's efficiency is not good. They are proposing that they are able to defy the laws of physics.
Will it work. Yes. Will it make more power? Yes. Is it the most ideal system? No.
