hey check engine light is on and i have no idea whats going on?
Avick
Car: Infiniti i30 2001
Hey i just needed some help about my 01 infiniti i30 it has 140k miles in it, the check engine light is on and recently when my car is stuck in traffic then the temp goes almost to the middle and then it doesnot bother to shift to the 2nd gear and i have to drive at 20mph but when i drive in highway there is no problem at all, the car goes smooth (the temp of the car is like in the 2nd or the 3rd line) and i have a small radiator leak is that causing the problem or something else. so basically if i m stuck in the traffic for long it happens can u let me know what exactly is the issue
Thanks Naeem
yangs13
Car: 1993 240sx-Dead, 2001 Maxima
take it to the nearest auto parts store that has free check engine light readings. they will give you a code that will narrow down what could possibly be wrong. the code will give you a definition of what is the issue...but you will have to narrow down what exactly is causing the problem. the internet is your friend...
Avick
i did go to autozone shows tht the speed sensor connected to the transmission has a problem as well as the oxygen sensors but they thing is tht i m wondering why does my car have the part of a 2000 infiniti i30 vehicle speed sensor instead of 01 vss
yangs13
I believe they are different sensors...maybe your vehicle was built late 2000, where nissan utilized the 2000 sensor
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
'00 and '01 should be the same.
Avick
bro i did fix my car then the engine service soon light went off and it is still of but now like 5 min bak my car started the same thing again the gear is not shifting i have no idea what is going on let me know the solution thanks
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Please clarify as to what have you fixed in the car. You have 3 issues - leaking radiator, and fault codes for VSS and oxygen sensor.
Did you replace the VSS? How's the level and condition of the transmission fluid. Is there any record of transmission service? Is the CEL on again?
Avick
i fixed my radiator and oxygen sensors and the engine service light went off so thought it is perfect and i dont know abt the transmission service as i got it in november 2009 what should i do? because the cel light is off
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
I suggest that you replace the VSS since you have a code for that earlier. Your transmission may get worse. It's not an expensive component (preferable OEM) and not difficult to replace (it's mounted on the upper RH side of the transmission housing and is accessible once the driver side wheel and wheel well cover (splash guard) are removed. Do a forum SEARCH if you want additional info on how to replace it.
Better do a pan drop, clean pan and magnets and check/replace the filter and install new gasket. You can buy Transmission Service Kit from IoS - infinitipartsUSA.com at 25% off MSRP. The bolts for the pan are one-time use but I and other forum members have recycled them w/o any problem. If you need to replace the filter, take note of the bolt position as they have differing lengths and one of them may be a nut (as in my 99 I30).
After the pan drop and ATF refill, have an ATF flush. At 140K miles, unless you have proof of previous ATF flush, most shops will refuse to do it due to liability issue. You may have to do 3-4 drain and refiill sequence to emulate a flush (ensure brake is engaged and run engine for @ 100 seconds while changing gears between drain and refill). You may need up to 15 quarts of Nissan Matic-D (OEM) but Dexron III and the newer Dexron VI should work
fiveliterbeater
Car: 2006 Mitsubishi Lancer Evolution IX
2000 Nissan Maxima SE
2005 Nissan Altima SE 3.5
what he said. i would highly reccomend a transmission service on your baby. one thing you should also check into is doing a diagnosis on the transmission itself. i remember on my old VE maxima, there was a code sheet of how to enter diagnosis mode and see if it threw anything at you. now that i think about it, the VE was OBD1 and yours is OBDII . everything may just be connected to the OBDII port.someone who actually owns an I30 will probably confirm or deny this.
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
Transmission Diagnostic Trouble Code is included in OBD with a Sub-System 7 designation. Below is how OBD II problem is coded:
*Systems:B-Body; C-Chassis; P-Powertrain; U-Network (LAN)*Code Type: 0-Generic; 1-Mfg specific*Sub-Systems: 1-Fuel and Air Control; 2-Fuel but specific to injectors; 3-Ignition or Misfire; 4-Aux Emission System; 5-Speed and Idle Control; 6-Computer Output Circuit; 7-Transmission Control; 8-addition transmission codes; 9&0-SAE reserved*Last 2 Digits-Specific Fault Code
Examples of OBD2 codes:P1320 - means a problem with the POWERTRAIN (P), specific to manufacturer (1), IGNITION or MISFIRE (3), Failure in the Ignition Primary Circuit (20)P0720 - means a problem with the POWERTRAIN (P), generic fault code (0); TRANSMISSION-related issue (7); Vehicle Speed Sensor, VSS (20)
Avick
alright bro i have done everythin my transmission gaskit and filter was almost dead had it done but came up with a new code P1126 ? Any idea about tht
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
P1126, depending on the manufacturer and model year can mean problem with O2 sensor, Throttle Control Motor Relay or a stuck/leaky thermostat. For your car, most likely it's the thermostat that's stuck open, leaking or installed incorrectly.
Make sure you get the correct gasket with the thermostat and install them correctly.
Avick
bro thnx for the advice as u said i did everythin except for the thermostat as i will do this by next week or so but i dont have the CEL and today i was driving and again it started the same thing it did not shift but i gave the car rest for like 10 min and then its all good and i see my temp gauge comes to the middle when i m stuck in traffic but if i m drivin constant in highway the temp goes low like the is in the touchin the second line above C so what should i do now i spent for than 800 dollars in like 1 month thnx and please help me out
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
You have to replace the thermostat. And if you haven;t replaced the VSS, you have to change it too. BTW, it's difficult to read your posting as there are no punctuations marks.
Avick
sorry for that, i read in some forums that they say its the vss, but once they replace the thermostat the car causes no problems so i better change that and try it out first. What do you think ?
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
04 G35 & 99 I30-RIP
I suggest you replace them both as you have a transmission and cooling system issues. These components are not expensive. You may lose your engine if you allow the overheating to continue. Right now, you are taking unnecessary risks. It's your car...your call.
Avick
alright bro i will update and let u know if it worked or not, thnx for the help bro!
