zsmith789 »
https://forums.nicoclub.com/zsmith789-u200892.html
Wed Feb 25, 2015 1:47 am
I'm not to Carbondale yet,.I'm currently finishing up my Associates at Kaskaskia, I'm in the Network Administration program on my second year, I'm about three classes away from my associates and both certificates that are offered in the IT program and I just decided a few weeks ago I wanted to go ahead and get a bachelors from Carbondale so I've got more pre reqs I'd like to get out of the way at Kaskaskia if I can. I'm living in the Fayette county area right now, unfortunately I've lived here my whole life lol.
As far as a power range, I'd be completely satisfied with the 250-300hp area for now. I've never had anything over 170-180hp so that much power would probably feel like a race car to me lol. This 240 was just given to me by my fiancé's aunt, her other aunt got a new car and gave her old one to the aunt with the 240 so she was just pretty well done with it. It was in rough shape, it had the common timing chain guide issue as well as a broken coolant reservoir and the rusted out exhaust system that is so common here in the rust belt, oh and the front seal leaked oil. She never did any sort of maintenance to it other than add oil when the light came on and it sat for a couple years before she got it. When I got it I tried to fix it up, I changed the oil and the poor filter, I replaced the air filter with a drop in K&N filter, I replaced the worn ignition system with NGK plugs and wires and a new cap & rotor, I got the OBX lightweight pulley set that included the A/C, power steering and alternator pulleys, I did that Sea Foam trick where you clean your vacuum lines with it and I replaced the rusty exhaust with a DC Sports header and the BRM exhaust system I discovered here on these forums, (which sounded beautiful!!) while I was doing that I took the intake manifold off and cleaned all the carbon out of it and repainted it. When it was all said and done, that worn out old engine actually looked pretty snazzy. This was my first actual build, I had a 92 Civic Si before this but my late father helped me a lot with it it not did most of the work himself lol. This one was all me! I learned a great deal, mainly that you get what you pay for and its better to do right the first time than to have to fix your mistakes on the side of the road lol. I'm not sure what did the KA in since I haven't got a look at the bottom end, but I have assumed it was either the OBX crank pulley or I didn't get all the seafoam out of the oil system when I tried to clean it. It started to make the ticking sound when I was passing somebody which I think was it jumping time or something and not even a mile later it died and wouldn't crank over again.
