Pharaohabq »
https://forums.nicoclub.com/pharaohabq-u94688.html
Tue May 27, 2008 8:09 pm
yeah like Evil said it depends on how far the crank has moved. Take off the Distrib cap and see where the bottom of the engine is positioned in relation to TDC, you can then judge the direction and distance to turn the crank by hand (spark plugs out of course) to TDC. You can also see where your cam is positioned by looking at it's timing marks. If the crank has to be turned more than about 1/4 turn, then you need to be VERY careful turning it, if you meet any extra resistance, then you'll need to stop and pull the head or just pull the cam to close all the valves so you don't bend anything you don't want to. if it hasn't moved far, you should be okay.
separately, you can see what pistons are coming up by where the dist is pointing. you can carefully turn the cam to close valves as the pistons are coming up, but you'll need to verify by shining a light through the plug holes. you've just got to be careful.
Phar
