hey, about to build turbo 200sx
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
UnderPressure
What parts change from the "S" chassis sr20det's to transverse sr20de's?say from the red topblack topblack notch tops15?
im looking more at cams, pistons, valves,spings, cam gears, injectors, fuel rails. . . . blah blah.
also, how much boost is safe on a stock sr20de with turbo kit?
thanksChris
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
If your going turbo, I would suggest buying a whole SR20DET. The sunny GTiR SR20DET would be an excellent choice: Quad throttle bodies, ball bearing T28, strongest stock internals of any SR20, etc...
UnderPressure
hmmm, really? how would that compare cost wise to the aprox $3500 turbonetics turbo kit?it will be my daily driver. short drives (5 miles or less) daily. and long *** road trips every month or so.
and what is the horsepower of the stock gti-r engine? thanks for your helpCHris
EDIT: oh and i want to stay emissions legal. :)
Onizuka
GTiR is 227hp stock and you can get the whole GTiR clip for $2900 or the motor set for $2400 from heavythrottle.
What state are you in?
UnderPressure
it will be registered in ATL Ga, im in statesboro ga tho.
Onizuka
There shouldnt be any problem then, as long as you keep a catalytic converter.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
