hestitate to move
infiniti2007
Car: 2007 infiniti g35x
Hi guys, I have little problems with my G (07 g35x ), every times when I drive , the car jerks , then it starts to move . But after it warmed up , then it runs really great. Does anyone have same problems?. Thanks
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
Are you driving your car really gently until its fully warm? If not, start.
What kind of jerk are you getting?
My wifes 4runner does the same thing. But its because of a 2 piece driveline that adjusts when you stop...which apparently is very common on 4Runners.
I've never heard of many problems from the X like this.
infiniti2007
Yes, I drive it very easy, I jerks like, you know when you drive stick and you let go the clutch so fast and accelerate to much on the first gear. But I got automatic transmission. It happens only when the engine is not warmed up.
infinitgkid
Car: '06 Infiniti G35 Coupe
infiniti2007 wrote:Yes, I drive it very easy, I jerks like, you know when you drive stick and you let go the clutch so fast and accelerate to much on the first gear. But I got automatic transmission. It happens only when the engine is not warmed up.
I think you just solved your own problem:
infiniti2007 wrote: It happens only when the engine is not warmed up.
Let the car warm up, and then drive it...
That's what I doThat's what my friends do as well...and It's been working so far
zozoka1212
Car: 08 Infiniti G35x
Yeap I never drive my car without I warm it up. That's how they were ment to drive. What kind of gas you putting in it? Regular or premium? How long you are warming it up before you go?
zozo
infiniti2007
Well, I always put 91 octane on this car , and I usually warm up at least 10 minute with my remote starter.
infinitgkid
infiniti2007 wrote:Well, I always put 91 octane on this car , and I usually warm up at least 10 minute with my remote starter.
Not sure if my car takes 10 minutes to warm up...
I usually just wait for it to get to 900 RPM and when I turn my car on up here in VA, it will idle at 1200 RPM right after ignition and slow decrease to the desired RPM.
It will usually take longer depending on the outside temperature...
I strongly urge that you make it a habit of warming up your car before driving it...
tollboothwilley
Sounds like its a transmission issue not an engine thing. I would call your dealer service dept and ask them about whats going on. Check transmission fluid level.
infiniti2007
I don't think , it's transmission problem. But I'll check the transmission fluid tomorrow .
zozoka1212
And after 10 minutes it does it? After 10 minutes it is pretty warm. I usually warm ine for about 5-6 minutes. If it is colder outside I might warm it up for little longer so I sit in a nice warm car. LOL
If after 10 minutes warm up it still doing it you have some problems.
zozo
infiniti2007
Does anybody knows, how to check the transmission fluid for G? I do not see any dip stick for transmission.
