DrifterProdigy85 »
https://forums.nicoclub.com/drifterprodigy85-u30257.html
Tue Sep 22, 2009 5:01 pm
Well im out of ideas on whats wrong with my car. Ive tried new plugs (.030" gap), ignitor, coilpacks, checked timing multiple times, new tps, 43psi fuel pressure, checked boost leaks to 25psi and found none. Everything checks out pretty decent with my wideband. Runs around low 12's in the midrange and richens to mid to low 11's at high rpm. It runs beautiful at 7psi but has a slight hesitation through the entire rev band at 10psi and the hesitation gets worse with 13psi. Would a bad knock sensor cause this? Would a bad MAF be causing the engine to go rich like it is at high rpm? Does anyone have a log of there AFR on a stock RB25?
