Ely »
https://forums.nicoclub.com/ely-u285175.html
Mon Apr 22, 2019 6:56 am
Update:
It did it again on the way home. After sitting and cooling off, we had no issues on the drive home until we got off the interstate. The off ramp near my house is at an incline so there was no getting going again. The other times I was able to get moving were on flat ground or a decline. It basically went into a neutral state and would not even hold on the slight incline. My thought, since it will eventually go, was to brake torque it until it caught and took off. Nay. It started making the smelliest smell that smelled so I quit immediately and called a tow. My CEL light was already on from running it with the air box out and the MAF sensor disconnected so I could hit the throttlebody with a little gumout in case the butterfly was sticking or something. Shot in the dark, but I felt like I had to try something. Hooked up my scanner when it got dropped in the driveway to clear the MAF code and lo and behold I had others. The dreaded P1778 stepper motor code. I did a lot of reading on that that (most links on google came back here) and found a good write-up on replacing it with a link to the stepper motor. The poster was describing doing this on an 2.5L Altima. So far, my search for what CVT is in the Quest has been a mix bag of nuts. Supposed compatible replacements have part numbers all over the place. Lean manufacturing being what it is, what's the likelihood Nissan paired the same CVT to the VQ35 that they did the VQ25?
I would much much rather buy the $35 part and put it in myself vs the stealership charging me thousands to replace the transmission. From what I'm reading, That's their only move.
I let my wife lose in my '18 Titan (gasp) this morning and drove the Quest to see how it would behave. Not surprised, it's running and "shifting" fine after sitting all night. Considering that distances she typically drives, it may not crop up again for a while, but I'd rather get it fixed sooner than later.
