mr_wizard »
https://forums.nicoclub.com/mr-wizard-u33966.html
Sun May 28, 2006 6:49 pm
Check your grounds, TPS, and spark plug wires. I'm willing to bet it's one of those.
EDIT: I'm not sure how safe it is to drive without your TPS, I know I've done it without problem but been told it's not a good idea, but I would try that and see how the car reacts. Now of course you won't be able to rev beyond a certain point (3k rpm), but it would run better if you floor it up until that RPM cut point if it was the TPS. ALSO, does it do this before or after it warms up? Is it worse before? Or after? Same?
