evildky »
https://forums.nicoclub.com/evildky-u13100.html
Sun Mar 18, 2007 6:19 pm
the looming you put on your O2 sensor wire will melt if it touches the exhaust manifold it's not rated for such high temps, if the wire is melteed you could have a problem but i don't think it would cause much running issue, maybe just a bit rich
how on earth would wone go about getting water in the cas tank? I highly doubt this is the problem
have you checked all the coil pack connectors? how do the plugs look? injector connectors look ok? CHTS? if it runs fine cold and starts acting up once it's warmed up I'd go for the CHTS
