rhetoric »
https://forums.nicoclub.com/rhetoric-u143180.html
Wed Sep 30, 2009 9:37 am
I thought I'd keep a bit of a journal on my new to me 1996 Infiniti i30 hesitation issue. I'll update as I attempt fixes.
Problem: Very subtle, but noticeable sag/surge/hesitation problem under moderate acceleration. I notice it mostly from a start. It's hard to tell if it's surging or sagging, but it's a steady rhythmic problem until you get to cruising speed at which point it runs just fine. Most people in the car don't even notice it. It DOESN'T do it under very light acceleration nor under heavy acceleration. I notice it more when pulling up a hill than on the flat. Most noticeable in 3rd gear, but does it in 2nd too. It feels more engine than transmission to me, though what do I know?
UPDATE 10/09/09 As I said in one of the later posts, the slight hesitation has turned into slight hesitation and serious intermittent missing and chugging -- usually under load. Yesterday it was rainy, today, essentially teh same problem, but it's dry. It did seem worse yesterday, but I also didn't drive it as much.
Solution Attempts: Trying to do the cheap things first and happy for suggestions.
Premium gas: No change.Air filter: No change.Synthetic Oil: No change. (but I didn't really expect it, either)Fuel Filter: No change. (thought I had it with that one!)Spark Plugs: Pending...transmission Chage: Pending... (though the fluid is nicely pink)
Modified by rhetoric at 7:52 PM 10/10/2009
