MarkEmark »
https://forums.nicoclub.com/markemark-u744.html
Sat Aug 07, 2004 6:12 am
Haven't posted about a technical problem in a while, but here goes...
First off, the setup...370cc SR injectors, JWT ECU, walbro 255 lph fuel pump, aeromotive adjustable FPR, 93 octane, alcohol injection, large intercooler, T3 super 60 B turbo @ 9 psi
I took the car out the other night (it was nice and cool, 59 degrees is what I like...) to do some tests using G-Tech, such as 0-60 and 1/4 mile and the like. When I was doing these tests, however, the car in first, second, and third gear past 5000 RPM or so under WOT would start hesitating noticeably (and not accelerate very quickly) and then would start making these really loud, scary sounding popping sounds, a bunch all at once and overlapping eachother, like backfiring....it would do it most noticeably in 1st gear, then not as much in 2nd, and not as much in third.
My fuel pressure was 32 psi @ idle (lower than stock to accomodate the pig-rich JWT ECU fuel program), so I bumped it up to 34 psi because I figured it was running lean in the upper RPM Range. It's noteworthy to mention that I'm not at a full 9 psi past 5000 rpm either, I'm at more like 7.5 psi around then (gotta love the tiny turbo). Anyway, at 34 psi it would still make the same incredibly loud popping sounds in first, second and third, and the tach needle would jump erratically (not smoothly) past 5000 rpm either. It did the same thing at 32 psi as well. I thought maybe I was misfiring, but I haven't thrown a code and this was 2 days ago. So I bumped the fuel pressure up to 36 psi, and it still does the same annoying popping sounds, but only in first gear now (or so it seems), so i bumped it all the way up to 39 psi and haven't taken it out yet. My question is, how could I be running lean, even at 36 psi, with a small turbo that's only at around 7.5 psi when the hesitation starts ocurring, especially considering the JWT program runs notoriously rich and conservative at stock fuel pressure (34 psi @ idle)?
My second question is: Are the symptoms I described due to running lean, or is it some other (worse) problem?
My third question is: why would it only do it now in first gear, and not second or third like it used to...is it because there's more stress on the engine in that gear?
I don't see how I could be running lean with the fuel system I'm running...and I previously have not noticed this problem, and it has ran very well at around 32 psi of fuel pressure for a while, but come to think of it, I rarely bring my car up past 5000 or 5500 which is when the hesitation starts...but if I need to run 40 psi of fuel pressure just to cure whatever this problem is, I think I'll be losing substantial power because the fuel pressure SHOULD be fine at the stock 34 psi.
I'm definitely going to invest in an air-fuel ratio monitor in the near future so i can see what the hell it's doing--anyone have any suggestions for what's a good monitor/kit that's ACCURATE and economical and isn't that much of a PIA to install? (It doesn't even need to be a permanent install)..I was thinking of a split-second air fuel monitor which uses a bunch of lights--my dad has it installed on his car and it seems pretety accurate.
Any help/suggestions is greatly appreciated.
BTW, for anyone wondering, my best 1/4 mile time (with all that hesitation and a crappy launch) was 14.28 @ 106.1 mph. (2930 pounds with driver and 5 gallons of gas)
The trap speed is pretty impressively high, but the ET seems very h igh for this speed--anyone know why this could be? 14.28 usually corresponds to around 100 mph...and 106.1 mph usually corresponds to a 13.5 or so ET.
