mello88 wrote:I bet you have at least one bad coilpack(s). My friend's RB25 does the exact same thing, it will drive under light load just fine, but whenever you go WOT it sputters like you've hit a fuel cut regardless of the RPM. Another symptom would be hearing it miss occasionally at idle, and if you stand in front with the hood up, you should hear a loud CLICK (sounds similar to a relay clicking on) from one of the coilpacks when it misses. If this is happening, then one of your packs is on it's way out. Unplug each coilpack individually for 30 seconds or so, if the clicking/miss goes away then you've found the culprit... We did this on his the other day, he replaced one pack, which pretty much solved the WOT stutter. Last night he was complaining about a 5000+ stutter, we popped the hood and did the above diagnosis and found another bad pack! RB25 Series 2 fwiw.
Could be a variety of other things too, but your symptoms sound identical.. GL
BTW, you already know this, but you should only be running 91+ octane on your RB!
wow... everything you said matches my problems... I noticed the loud ticking, almost like a valve tick or a relay switching constantly, but i just figured that it was just the characteristics of the injectors... I also just found out tonight, that the car will stutter at any range, regardless of rpm.. Before, i just kept ripping through teh gears sequentially.... this time I pulled in 3rd gear at 3000 rpm and it sputtered much sooner... (around 4500)
Thanks for teh info!!! I will def test the coilpacks tomarrow.
