I assume you mean like this:06M4.5 wrote:It may be the gas pedal recall new update (download).
TDot wrote:Did you have this issue before the work? If not, why do you think it's not because of the recall fix if in fact your car is well maintained?
hormy83 wrote:I have noticed something similar, although I haven't noticed the shifter surge back and forth. It is at the same speeds you mention and only on flat ground while having the accelerator pressed just enough to maintain speed. It is very slight and only at a a very narrow speed variance.
Post up if that works for him, as I am interested as well!lovemycarM35 wrote:hormy83 wrote:I have noticed something similar, although I haven't noticed the shifter surge back and forth. It is at the same speeds you mention and only on flat ground while having the accelerator pressed just enough to maintain speed. It is very slight and only at a a very narrow speed variance.
Yup that's it, and yes only at low speeds and random I took my car out yesterday and it was fine no SES light so I'm not sure what to do there is another thread going with a member who has the exact same issue as me he thinks it my be bad coil pack and he's replacing all six I'm waiting for him to follow up
Bad coil pack I'm replacing all sixM35austex wrote:I had a very similar issue on my 06 M35. Probably around that same speed and under light acceleration. I never had it checked out because I figured i'd never be able to replicate it for service. I've never had anything like it on my 12 M37.
