hesitation in throttle
TmaCular
Car: 1994 Q45 150k
im having some hesitaion issues at low rpm on acceleration but when im cruisin or accelerating at higher speeds its just fine?? its a 94 q45a!!any ideas thanks in advance
96Qowner
Car: 1996 Q45
It might be as simple as a corroded connector. Pull and clean the MAF and CAS connectors first - coat 'em with a little dielectric grease and and snap 'em back together and see if that helps. A bad MAF or its connector will cause bucking at low speeds.
Check out this article on cleaning the MAF:
http://www.q45.org/maf.html
If that doesn't fix it, I'd try
1. BG44K - put a can in a full tank and change the oil shortly afterwards.
2. Clean up the intake path either manually or with a BG or other intake cleaning process.
Q45tech
Have a Consult diagnosis to make sure KS are ok by now 12 years most have failed from heat.
Generally 96 was the worst accelerating engine in the 90-96 series due to lack of VVT and detuned emission timing [cams different from 90-95].
New sparkplugs, BG44k, extensive intake and MAF cleaning, transmission ?
TmaCular
Car: 1994 Q45 150k
plugs are next i did the fuel treatment with chevron/techtron cleaned maf really well. i dont know what KS is ? and as transmission i think she could use a flush or change. would you suggest flush with 119k miles on it. or should i just drain it and change the filter? thanks
96Qowner
Car: 1996 Q45
KS is Knock Sensor. You can't get at 'em, though, without pulling the plenum off - big job. You easily ohm them according to instructions here:
http://www.q45.org/ohminjectors.html
As far as the transmission, most recommend dropping the transmission pan and cleaning it out - be sure to get the entire kit - gasket and one-use bolts. Then do a good flush with either a BG or Sun machine. If your fluid has been abused, you'll want to get the chemical flush.
Congrats on the car, BTW. The Q45a is a special model! If you need any advice on the ACTSUS, get ahold of Keith:
http://www.activesuspensionsystems.com/index.html
TmaCular
Car: 1994 Q45 150k
thanks on the compliment and thanks for the help i was thinking the other day and was like o yeah knock sensor lol. but yea she is a beauty doin some body stuff in the spring. but i just opened up to a world of cars i do not know. so i appreciate the help. i finally got a check engine light so we'll see what she sais. thanks again
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
http://www.bgfindashop.com
Read up on Q45tech's posts on what constitutes a true and proper mechanical ATF exchange.
Add an auxiliary ATF cooler while you are at it. Migh consider changing external ATF filter also.
texasoil
Car: '92 Infiniti Q45A
'94 Infiniti Q45A
'94 Mercedes-Benz SL600
I had a customer's car with somewhat similar intermittent misfire-that would be real bad when 'active' then behave real good for a while (days),then...
Since I cleaned and used Stabilant 22 on ALL the engine connections, runs great--3 weeks and going.
