hesitation in throttle response
TmaCular
Car: 1994 Q45 150k
i have a 94 q45a recently converted suspension over due to fried pumps and accumulators.. everything on it works perfect and it runs beautiful. but i notice in lower rpms accelerating is hesistant possible fuel filter?? i just got home from a 1500 mile round trip to ny and it ran great at high speeds and cruisin so i would not think a fuel pump or relay issue considering fuel pressure must be ok but i also do not know much about these cars any ideas to check out?? thank you in advance for ur help
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
fuel filter, throttle cable, dirty injectors, air filter, maf \i would change the filtersrun a tank of gas w/ BG44 or Techtron.change air filter clean Mass Air Flow SensorCheck tension on throttle cable
sdkhalsa
Car: 94 Q45 06 M35
A common cause of hesitation are the infamous knock sensors which will cause ignition to retard. A quick ohm check will normally tell you the story. Another positibility is the TPS.
