hesitation in my black top sr
S13 Madison
Car: 1993 240sx hatch
I have a s13 blacktop thats hestitating maybe 50% of the time. Its a running swap that has been in the car for about 2 years. Its pretty much stock accept the fmic. Idk where to starthelp?
Steady_One_S13
Car: 1991 SR'd 240sx S13, 1993 Toyota SW21 Mr2...
I saw, try cleaning the MAF with maf sensor cleaner. Then check TPS for correct adjustment.
If that checks out, then inspect and clean the IACV.
Btw, check all hoses for any leaks.
MrSoutherland
Car: S13 - Sr20
Probably a bad hose or connection some where. Just start checking everything ^ said and some.
newdude1
Im having a similar problem. What hoses should I check?
ProjectGarage
Car: Hehehe.
newdude1 wrote:Im having a similar problem. What hoses should I check?
Check all that have any vacuum going though them. Also when you check the TPS make sure its actually functioning correctly it could be bad.
Another thing is your coil packs may be going bad and are intermittenly working.
Good luck!
