Load based problems are usually MAF related.jertapper wrote:Ok...information I left out:
-no check engine light (as others have said)
-seems to only want to do it under load (when it's doing it, if I throw it into neutral it revs as I would expect it to)
No, there isn't a spare resistor just hanging out for you. loljertapper wrote:I do need some help on locating the knock sensor and what do you mean by "install the 1.5 megaohm resistor"? I might have a 1.5 megaohm resistor around but are you saying one already exists for me to use and it's just chilling in case I need it? That seems strange to me.
There could be a stored code without a cel, yes.jertapper wrote:Ever since this started I have tried putting some fuel injector cleaner in the tank when I filled it up and also have been sure to use the highest octane whever I fill up. (Those alone didn't seem to help, but I was convinced the maf cleaning worked until today, grrrr).
I have read the sticky about the codes, downloaded it even. What are the chances that there would be a code indicating the problem and the check engine light wouldn't come on? My friend has an obd2 scanner but I haven't bothered to borrow it due to no check engine light.
Resistor or knock sensor? Resistors are cheap. The knock sensor, I found on ebay, brand new, for $60 and you will want to relocate it to keep from having to get to where the original is so you will want a wiring harness also. Those are about $25 from the dealership.jertapper wrote:So, you suspect this sensor is bad and I can do some electrical test with my multimeter and a 1.5 megaohm resistor to see? How much would a new one be? Is the install is pretty simple? How much are they?
Too much, see comment above.jertapper wrote:EDIT:
SWEET SASSY
Description Year MSRP Price Core Price Your Price knock sensor, j30, q45 95-01 $168.18 $0.00 $129.50 Electrical - Powertrain control - Powertrain control - knock sensor
that sucks
So what is your car? A 95 or 96? The 8th character from the end on your VIN tells the year. S would be 95, T would be 96. And if it's a 95, it might be OBD1 which you can't hook up to your buddy's scanner. There is a sticky at the top of the forum to tell you how to read codes on OBD1 J30s.jertapper wrote:I did some more searching and see that people say the knock doesn't make the check engine light come on. This is a 96 or 95 so I'll have to get a scanner and check the codes if there are any.
No, to replace the original knock sensor would take a huge pile of money. In fact, the dealership here said they wouldn't even do it for me. Too much time. Look into relocating the sensor instead.jertapper wrote:Apparently it is also not easy to replace. That's great news. What would be a reasonable labour charge to do the job?
You have a 97 (V) which is OBD2.jertapper wrote:LOL, 8th char from the end is a 'V'.
And my wife has the camera that I took pictures of the MAF with (of course I didn't take them off).
Anyway, I cleaned the maf with the stuff I had laying around that I thought was good enough to clean it with. I cleaned it with this stuff:
http://www.abra-electronics.co....html
Except a spray version.
Is that not good enough? Or possibly my maf is faulty.
Maybe what I used is the reason it seemed to clear up then come back a week or so later?
I took off the air filter cover and sprayed the little tiny thing inside...it was similar to a light bulb filament. That was the maf, was it not?
I also disconnected the connector for it and sprayed in there. Now if we could get this year deal straight I'd find out if I need to get a scanner.
What did they charge you?Pogophil wrote:Had the dealer replace the knock sensor in the original location.
You don't need a new harness. The only reason you use a new harness is when you relocate the knock sensor and you need a new one then because you can't get to the original knock senson to unplug it and reuse that harness.gotspeed wrote:I would also check the harness and make sure that its not the old one that they left on there. You are suppose to change the harness as well as the sensor.
These things you mention, would any of those problems actually cause that code and the knock sensor actually be functioning properly?Q45tech wrote:Always test idle, cruise, and WOT fuel pressure as a pump slow down can drop pressure to point where acceleration is more than just sluggish.
Won't throw any codes that would indicate the problem other than wating adaptive learn trim at WOT..............or O2 voltage [lean when it should be rich].
If you got that code, it's because you have a bad knock sensor. As a result, the ECU is retarding the engine timing, robbing power. You need to fix it if you want any hope of solving your problem.jertapper wrote:
Yoda, I'll have to respectfully disagree with that comment. The ECU would retard timing regardless of the rpms if the knock count is high enough. (I've actually seen this happen while datalogging my Stealth.)yodawill2000 wrote:Just a fyi. the knock sensor is ignored when the Tach hits 3500 and up, At least thats what Ive read here.That would explain why the engine kicks back in when you open her up.
What do you mean "undo right from the sensor"? Undo from the original sensor? If so, then you don't need to get a new harness. The only reason to get a new harness is because you can't get the old one off.jertapper wrote:I'm pretty sure the knock end would be right. I'd be willing to rig up the other end if I had to...even solder it. Since I'm relocating it, it won't be hard to undo right from the sensor.
