The symptom goes away once the car is warmed up fully.
Did anyone experience the same and know the cause to this buckling problem? 1996 G50 Q45t with OBD2 ECU. Manual swap done with these codes constantly popping up : P0600 -> TCM control malfunction P1336 -> crank angle sensor installed but pointing somewhere just off the gears of the flywheel so it's "erratic".
I tried to replace the coolant temp sensor right in the front side of the engine but no socket can fit into that tight spot...I don't want to remove intake plenum in order to do that....Is there any other methods/tools you reckon I could use to try and replace the ECU coolant temp sensor? (located just behind the fuel line bridge between the banks and in front of the plenum) no 19mm socket is long enough yet short enough to go in there and turn the sensor out...
But that's my speculation anyway what's the really likely reason for the car to buckle at 1000-1500RPM ONLY and nowhere else?
