DevilMB3017 »
https://forums.nicoclub.com/devilmb3017-u47101.html
Tue Oct 14, 2008 11:05 am
It sounds like you might have a vacuum issue somewhere. This could cause your boost to drop because the wastegate is opening incorrectly, or your blowoff valve is popping, or your fuel pressure is dropping...
I'd check all your vacuum lines and make sure everything is okay.
Edited to remove stupidity.
Modified by DevilMB3017 at 6:06 PM 10/14/2008
