LFTM-DFTP »
https://forums.nicoclub.com/lftm-dftp-u50834.html
Fri Jun 22, 2007 3:25 pm
Okay guys....sooo I bought a 93 coupe about 2 months ago...it had slight hesitation but it was nothing bad...anyways I let it get worse to the point where it would hesitate on start and would just die. so I said its now time to fix this.....I was going to just put in a new engine but I said to my self that if its not the engine i am in the same hole with with a different shuvell....soooo I decided to change the MAF sensor...fixed the problem when it dies on startup...but the boggle and hesitation was still there...I then cleaned out my throttle bottle...fixed it a little bit...then changed the fuelfilter and small leak in the fuel line....nothing to noticable...sooo I cant think of anyone but a clogged CAT....and It doesn't feel like it could be...when I am soft on the throttle the car runs fine..but when I try to accelerate it just doesn't want to go and the engine makes a deeep sound like a clog or leak........I dont know what else to do!!!
also...I forgot to metion that I changed the cap and rotor...not the lines "I know!"...but they looked perfectly new to me...but one thing that really scared me is that when I changed the spark plugs...spark plug 3 and 4...had oil all over them...could I have blow a piston ring or something...I dont know what it is!!..guys help I need to fix this!
