abyss »
https://forums.nicoclub.com/abyss-u133525.html
Mon Jun 08, 2009 5:01 pm
I too have noticed this hesitation. It occurs at around 40 mph with the car in 5th gear. The engine seems to be turning at about 1150 rpm. When trying to accelerate, there is a momentary hesitation before a downshift and acceleration. I believe what we are all experiencing is the unlocking of the torque convertor (Steve, cover me on this). But this car, like all automatic transmission cars now, have a locking torque convertor. The torque convertor is a fluid coupling between the engine and the transmission, allowing the transmission to change gears. But as a fluid coupling, there is some power loss, due to the convertor. In an effort to eliminate these losses, the torque convertor can be locked, thereby eliminating the loss. Now generally, the torque convertor will only lock up when the transmission is in the higher gear ratio. Once locked, the transmission can not downshift to a lower gear until the torque convertor has had time to unlock. and hence, the hesitation we are all experiencing. At 40 mph and 1100 rpm, I am not even sure how much pressure is readily available to unlock the convertor, so the transmission can downshift. This seems to be an issue of over-zealous programming of the torque convertor to increase mileage. I would think Infiniti should look at increasing the rpm range before it allows the torque convertor to lock up, such as in the area of 50 mph. I am not sure how much fuel economy advantage there is in locking up the convertor at these low speeds, as opposing to the increased time it takes to unlock the convertor and achieve a downshift and acceleration.
