hesitation and popping under WOT @ 4500 rpms
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
throwing a code 11.
only symptoms area hesitation and rappid popping (almost sound like rappid backfire) after 4500 RPMs and only under WOT.
are these symptoms consistan with a bad CAS?
i just recently got the timing set right, could that cause me to throw a code 11 (messing with the CAS)
and is there anything that could cause me to throw a false code 11.
thanks.
-terry
float_6969
When you check the codes, it clears them out, so go back in and check them again, if it's still there, then you do in fact have a problem with the CAS.
The symptoms are hard to pin down as it can do all kinds of screwy thing.
