hesitation and bogging under heavy acceleration
nvsn8
Hello everyone,
Here is a good one for the achieves.
I have an SR in a 1990 240.
Problem:
If I drive like a grandma and shift slow thru the gears it is fine.But Under moderate to heavy throttle my car hesitates, bogs backfiresin the down pipe. Around 2500-3500 rpm.
To start trouble shooting, I changed my sparkplugs to ngk 7s wasrunning 5s for a short while.
I checked the intake pipes I noticed my HKS filter nut fell out andthe filter was slightly open. I got a screw tightened it up.
I have tried to reset my ecu to see if it was sending a bad readingfor air mixture due to the air intake being loose.
I then checked the ecu for codes and it came up with 34 knock sensor.From what I hear that means the knock sensor is not bad it justtriggering it.
Only thing I can think of is the loose intake filter caused thetiming to be advanced and is throwing the knock sensor.
I was thinking of checking the timing next. But I thought yell mighthave some ideas first..
Thanks in advance, and if anyone in the orange county area wants tohookup and talk cars hit me up,
Aim: envsn8thanks Eric
[s3]
34 Knock sensor will most likely send most Nissan cars into limp mode.
The ECU will log "problems" with sensors, logging a 34 means theres a problem with the sensor, either unexpected voltage or no signal at all.
nvsn8
thank you for your reply.
Do I need too replace the sensor?
[s3]
1) Run the car
2) Check for codes again
3) repeat process to make sure its a 34, replace/repair sensor as needed
