billg »
https://forums.nicoclub.com/billg-u17618.html
Mon Jun 28, 2004 5:35 pm
Thanks for the reply. Very good questions and I do not know the answer to any of them. The car was picked up at a dealers auction, without any maintance recoreds. A freind of mine will sell it to me for about $5500, not including fixing this one problem.
I drove the car to work this morning and it ran great. I know that when I drive it home tonight in traffic, I will see the problem again.
I guess I should try the lower cost items you mentioned, since they would be good to change anyway.
It seems there are a lot of similar problems like this on the forums. I have seen a lot of the following suggestions but there doesn't seem to be a definate answer. O2 sensor, MFA element, Knock sensors, throttle body and planum, EGR value, Coolant temp sensor, Engine timing, fuel injectors.
Any thought of these casuing this problem. I pretty sure this problem only happen when the engine is hot and mostly when i get in stop and go traffic.
