Hesitating Accelerating in 1st
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
Aven
Car: 84 720 Kingcab
I've put some time in on the truck lately. I replaced the oil pump, the oil pan gasket, the battery cables with 2 ga, the fusible links with inline fuses and got the driver's seat bolted in place. So I took it for a ride. It seems to have developed a tin can death rattle and hesitates when I accelerate from a stop. I'm wondering if it might be the cat.
PEZi
Aven wrote: It seems to have developed a tin can death rattle
please elaborate...
Aven
Car: 84 720 Kingcab
I can hear a bit of a constant rattle when the hood is up, but I can't locate it. It seems to be coming from the driver's side of the engine, but I'm not sure. I tightened down the air filter, so I'm sure it isn't that. When I took it out around the block, I heard a tinny, hollow rattle, almost like I was dragging something. I checked all around the truck and under it, nothing looked out of place. It wasn't constant. It almost sounds like some one dragging a muffler.
captainzeros
Car:
1981 Datsun 720 Longbed
1973 Datsun 240Z
Sounds like the heat shield around the exhaust manifold or the heat shield around the catalytic converter.
On my truck, if I open the driver side door and slowly run the revs up in neutral there is a place where the heat shield on the cat will resonate and rattle like crazy, a little less or a little more gas and it's fairly quiet though.
Aven
Car: 84 720 Kingcab
I'll crawl under it once it quits raining and have a look.
noface
Car: 1985 Nissan 720 4x4 King Cab
I was going to suggest the heat shields too... I'd also check for any exhaust leaks, particularly at the head pipe collector. These things are notorious fro cracking...
Could it be the engine is pinging (timing to far advanced). Is the noise internal to the engine, or external?
Aven
Car: 84 720 Kingcab
I don't think it's the timing. It sounds more like the exhaust to me.
I'll take a look at it tomorrow hopefully.
Return to “Datsun 720”
