Hesitates and stumbles on acceleration
vv64581
Car: 1991 Nissan 300zx TT
I bought a 91 300zx TT 5 months ago that had an engine /transmission swap 2 years ago. I'm told it has about 40 K miles on it. It ran perfectly until about 1 month ago. It started running rough at idle but ran great when not idling. A few days later it started running great all the time. about two weeks later it started running rough on acceleration but idles great. When not in gear you can rev it up and it sounds perfect. Only under hard acceleration does it stubble and hesitate. I read several of the posts and cleaned up all the electrical connectors. That didn't seem to help. I took out all the plugs and they look great. The turbo boost upon acceleration also looks normal and smooth. It's a beautiful car but almost can't drive it anymore because it hesitates so violently when I accelerate above 2500-3000 rpm's. Anyone have any other idea's? Could it be the turbo's?
es.biggs
Car: 1990 300ZX 5sp NA
Always a good idea to verify ignition timing is properly set.
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
Is it an issue with the rpms of the engine moving violently or is it more of a chatter? May look into flywheel chatter and make sure everything in the drivetrain is in good working order.
vv64581
It appears to be from the engine . No chatter that I can hear.
Z31toZ32
Car: 1999 Infinity QX4
run the codes, see if it spits a trouble code
robomatic12
Car: 1990 300ZX TT
You have verified the engine is running on all 6 cylinders with a power balance test? +1 on checking for codes
catnipple
Car: 2007 z33
1990 s13 hatch (ls1 swap in progress)
1997 dodge 1500
2004 dodge 3500
my buddy had one that did the same thing n something with the timing caused n the spark plugs is what it was. there was like 2 spark plugs that were screwed n as soon as he changed them for cooler ones n tweaked the timing it ran great.
vv64581
Thanks for all the replies I will try these suggestions this weekend
