Hesistating...
For discussion of front-drive SR20DE, SR20VE and SR20DET engines!
niSssEanR
Car: 1992 b13 SE-R
I just did a tune up on my car, a 1992 Sentra SE-R, new plugs, new wires, new cap and rotor. Cleaned out the intake manifold with some stuff that goes through a vaccum line. Did a oil change. Nothing out of the norm.
Now, it is acting up. It is hesitating in 1st and 2nd gear. Some stumbles in 3rd and 4th, but mainly in 1 and 2.
Does anyone know what i can try to fix it, what it might be, any ideas at all?
I am really gettin pissed at it, so mad, i dont want to drive it, and for me not to drive the SE-R, thats nuts.
But thanks for any info, even it if dont help, i thank you for giving me your 2cents to try to fix it._________________
niSssEanR
Car: 1992 b13 SE-R
BUMP... still need some help. Thanks
nametakennow
Car: '06 MINI Cooper S
That sounds like an air issue, any trouble with idling?
niSssEanR
Car: 1992 b13 SE-R
My Iidle is perfect, nothing wrong till i give it some as at low RPM's.
nametakennow
Hmmm... throttle position sensor is the only thing that immediately comes to mind.
niSssEanR
Car: 1992 b13 SE-R
How would that get messed up from anything i did? I put some stuff in there to clean out the intake manifold, then i cleared out my cat cuz it was clogged. I also put stuff in the gas tank, so thinkin it did its job, i replaced he fuel filter.
Whenever i let off the gas, i get a 'crackeling' sound going through my exhaust.
nametakennow
The crackling is common in any car, it's just a little backpressure when you let off the throttle, no big deal.
It may not have been messed up by what you did, though it's possible that cleaner you ran through got on the sensor somehow.
Like I said on IM. I'm trying to think of anything related to acceleration based on what I can discern from your posts. Without seeing the car, it's harder to tell.
niSssEanR
Car: 1992 b13 SE-R
nametakennow wrote:The crackling is common in any car, it's just a little backpressure when you let off the throttle, no big deal.
it didnt crack till after, i never heard it before till it started running like crap
Modified by niSssEanR at 6:56 AM 5/18/2006
nametakennow
I still doubt the sound is related, it probably just wasn't noticed til you had this issue.
Any luck on the TPS? I haven't had a chance to download the B13 manual and look for the info yet.
niSssEanR
Car: 1992 b13 SE-R
i didnt have time to test it today, i am tomorrow. The sound was never there. I know for sure
nametakennow
Hmm... I suppose it's possible that the sound and problem are connected, but I'm not sure how.
Anyway, TPS should read .4v to 4v depending on position. See where it is at idle and at full open and if those two numbers are .4ish and 4ish.
niSssEanR
Car: 1992 b13 SE-R
Well i am still having trouble with my car. Come to find out, my buddy says the cracking noise is like a back fire, but it is right around the header. So he is thinkin, if it is like a Honda, then something to do with ignition. But i had my timing adjusted a while back, didnt help. I took all the **** off the front of the motor. PLEASE help. getting real tired of it. Tired lots of things.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Exhaust manifold gasket maybe shot or the header is cracked. The Gen I hotshot headers used to have this problem.
niSssEanR
Car: 1992 b13 SE-R
Most of the problem fixed when i finally replaced my o2 sensor. Still have very little hesitating in 1st when it is cold.
Return to “SR20DE / SR20VE / SR20DET Forum (front drive)”
