heres the verdict
nd_aussie
Car: 1994 300zx 2+2 bout to be tt&1987 rx7 s5 turbo II
ok so i pulled both of my wheels off to check and play in the rear. i noticed that the driver side rear axle has a lil bit of play(yes this is the side my bearing blew out of) this is not normal right? so what does that mean if it has a little bit of play(its side to side not up and down play)
Ace2cool
Car: 1991 Nissan 300ZX TT
1966 Datsun Fairlady 1600
2005 Suzuki GSX-R 600
1974 Honda CB550 Four
2009 Ford F150 Lariat
An axle is a rotating assembly with a CV joint. There's no way it has side to side play but not up and down. That's not going to be causing a grinding sound either. I think you got your wheel bearing messed up somewhere while you were repacking it. Either that or it's the diff, like you said.
Jack up the car, and turn the rear wheels by hand. Listen. Pinpoint sound, troubleshoot further based on new knowledge.
Also, please start posting these threads in technical. I'm moving them now.
nd_aussie
the axle going into the diff is moving side to side like in and out, i turned the wheels i started the car put in in first let the wheels. spin. nothing. sounds fine. it only makes a grinding noise certain times. making hard corners etc
Ace2cool
That still sounds like the wheel bearing to me.
How much would you say the axle is moving? 1mm? More? Less?
nd_aussie
1/8 inch. just the axle tho
es.biggs
Car: 1990 300ZX 5sp NA
I think you got a bad bearing or it was pressed/installed wrong. A little horizontal play in the axle is normal. What you want to look out for is rotational play.
nd_aussie
its horizontal play
Ace2cool
Then the axle is not your problem.
