heres the install info for the auto dim mirror swap
heywier427
Car: 91 Q45
there are 4 wires coming off the mirror.
tie the black and green together, thats the ground. to be tied into the map light ground(black).
tie the red and blue together, thats the switched power. to be run down to a switcted power source. the easiest one is the illumination fuse in the fuse panel. use a small screwdriver to push the wire in, then replace the fuse. or if you have any of the wires that the cell phone used, they will have the proper piece of metal to push into the fuse bay.
the pictures wil make up for my lack of brain power. sorry about the size of them, im to lazy to resize!
hope this is a helpful on this mod install
heywier427
Car: 91 Q45
heywier427
Car: 91 Q45
heywier427
Car: 91 Q45
heres my next project. led reverse lights. theyre really freaking bright!
lino
Car: 1991 Q45a Fed-Spec, IQP/White, Texasoil 9 Accumulator Recharge, '93 TCU 1st Gear Start, JWFSB, B&M 70268 Transmission Cooler, BBS Forged Wheels, DRLs, Silverstars, Tint, Very Well Serviced.
What year model car does the mirror come from? Does it work well?
heywier427
Car: 91 Q45
94 Qs n up. my car hasent left the garage yet. youll have to ask a 94 owner
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
Hey with this setup does it work as it would on the 1994 Q45?
Kiven422
Car: '93 Infiniti Q45
'94 Infiniti Q45t
As long as the mirror gets power it should be able to do what it was built for.
I have never seen my auto-dim in action... It could be because my sub blew the shiz out of my mirror though.
Infinitiguy19
Kiven422 wrote:As long as the mirror gets power it should be able to do what it was built for.
How did the sub blow the mirror and are you sure you didn't blow up anything else?
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Kiven422 wrote: It could be because my sub blew the shiz out of my mirror though.
Wha..??? Didja say sumthin? I couldn't hear you!
Kiven422
'94 Infiniti Q45t
My mirror is loose. On hot days it can easily shake out of its place. At night it sticks to its position though.
My subwoofer shook the mirror to near-death. But its okay, I think it just needs tightening.
I have a 15" square subwoofer with an 80+lbs box. Suprisingly the G50 is a well made vehicle. Still no interior rattles. Everyone listens to rattle as they play their beat, cept me.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Kiven422 wrote: Everyone listens to rattle as they play their beat, cept me.
Don't worry! Hearing damage is progressive, so soon you won't be able to hear the rattles either.
So back to the mirror, are the wires jsut hanging out, or are they rerouted to be hidden?
qsiguy
Car: 1994 Infiniti Q45 Turbo
Correction to the above wiring suggestions. The black is the only one needed for ground. The green is just for the dimmer. Not needed unless you want the "Day" and "Auto" to dim with the dimmer knob.
The red and and blue both need to be powered to get the mirror operate. Normally the red is powered by the ignition switch and the blue by the parking light circuit. You can wire to a switch or wire into the parking light circuit so they always work when you turn on the lights. I'd fuse them with a 5 amp fuse to be safe.
Not sure what I did but before this research my auto dimming mirror did not work and after I've been messing with it to decipher the wiring it's started working. I think it was when I pulled off the cover around the "Day" and "Auto" buttons.
