I worked part-time in the heat treating business so I can agree with everything you just said.LongBeachCoupe wrote:I dont mean to be an arse about it... and i assume it wasnt your car... But you have to be out of your mind to heat metal like that in a confined area where there is so much going on... lets say you are dead on accurate at pointing the torch where they need to, and dont burn anything around it (seems like youd need to be a surgeon).... but changing the properties of the spring by weakening its strength thru heat is just not a logical idea in my mind. Maybe someone with more experience on cars can chime in here, but it just seems like they are out of their element doing something like that... (your out of your element donny! shutup! hehe)..... Id consult with someone whose got more experience with chemistry rather than a guy who doesnt see anything wrong with this... i could possibly be 100% wrong though... anyone else hear of this?
Hey man, no flame taken (except of course, by the torcher above, hahaha). ANd I NEVER would have really taken this spring cutting idea seriously except that it was suggested by a nissan employee whose been at nissan for like 20 years, and said he's done this "several times" with no problems. SO, it got me thinking, "ok, hmmm, maybe..." THen, when he told me the springs were only $25.00 I figured, damn, no reason not to try it, can always just undo it. THe front prings are more, so he was $50.00 off the cost of four, but no big deal.nissantech06 wrote:
GreyZone, I hope you know I'm not trying to flame you, just warn you of something stupid I did. If you want to do it, go right ahead, but I'm telling you the effort isn't worth it (cutting the springs).
not true...when metal is heated, it will be weak until it cools off... as its weakened the spring will lower due to the weight but it will remain like that after it cools and will be STRONG as normal but the spring was not "shortened" just compressed, making it a bumpier ride, but strongLongBeachCoupe wrote:Exactly... heating something can essentially bring it to the point where they snap if you hit a pebble... you need some pretty complex machinery to make sure the spring is still in spec as far as its strength... I can only imagine what would happen if one of the springs snapped while you were on the highway...
Steel is a very peculiar metal. I took a few materials classes in college and also interned at a manufacturing plant with an extensive heat treat department. Depending on the temperature, makeup of the metal, time exposed to the heat, and cooling process Steel can be go from extremely brittle to extremely flexible. Without the proper processes of heating and cooling, it will be next to impossible to predict the outcome of just "heating it up". IMO this is not the route to take. Heat it wrong and the thing could snap on the first pot hole you encounter.LegendRacer wrote:
i have seen this done and it works well from what i heard
Those are some excellent ideas. I'm not sure if the springs are slotted or notched, that's something I will be doing more investigation into. Technically, some from the top and bottom is a good theory.Datalux wrote:As for actually cutting the springs, I would use a good band saw with liquid cooling capabilities since you want the spring to see as little heat as possible to retain its strength. Second, I think I would cut half off the bottom and half off of the top. Most springs are progressive, so if you take it all off of one end, I suspect you would be losing the majority of a specific load bearing characteristic. I'm not sure this would actually work as I seem to recall that springs are keyed and each end of the coil needs to sit in a certain spot at which point your stuck cutting exactly one full revolution from either the top or the bottom to keep them aligned.
Good luck and report back soon!!
