Aftermarket rad caps are'nt always a good idea. They hold TO much pressure , wich causes the thermastat to open ealier and can cause hoses to blow.Jadesr20det wrote:i would hate to think that my brand new nismo rad cap is bad lol
yea i know that to be true. i just sat outside for anothe hour rebleeding the system and havent had another issue yet. i think my car just doesnt like sitting around not being driven for awhile lol.Slappy wrote:
try kicking it?nismoracingsx wrote:coolant temp sensor is also new, but i'll look up how to test it, just in case..tried driving to school today and i only got 10 miles before i had to turn around and gimp it home...i don't think i've been this irritated and depressed in a lonnngggg time .
I removed it all together so that couldn't be it. The heater hose leaking from 2 holes was causing my problemFUNS14 wrote:Have you checked the thermostat?
thing is i had a nismo t-stat in there b4 took it out about 2 days ago i even tested the stock one in hot water when i took the nismo out i tested that one also. Both passed w/the nismo opening a bit earlier (as its supposed to). My cooloant wasnt rusty as i bought a brand new koyo rad with the swap as for water pump i never had the heating issue till recently. The car idled for 1 hr outside no heating issue (w/heater on full blast). So while driving the car this morning it got hot i didnt panic just pulled over (in an retired persons trailer park). I hear this noise like a sprinkler starting up im thinking to myself "great now imma get soaked on top of everything" pop the hood follow the sound and see 2 pinhole sized holes in my one heater hose with coolant bubbling and hissing out of it (small amounts).Theres my problem because before that car ran perfect and when i added more water coolant on the way home no problems. So in conclusion the motor gets to operating temp coolant starts leaking out of said hose and slowly leaks out over a few days of driving when coolant runs dry car starts to heat up. End of story needless to say ill be changing it out this weekendcarbully wrote:xekushnr is right when earlier he was alliding to the fact that it would help to really know how hot it's getting. You are right, small holes in any hose can causeair to get sucked in when it cools off. How long ago did you remove the t-stat?
The reason I ask is that I have seen cars overheat becuase the t-stat was removed. The T-stat also serves as like a restrictor to the flow of coolant, and when removed the coolant does not spend enough time working though the radiator. So, instead of being cooled to say 160 on the cold side of the rad, it is being pushed out when it's still like 175 or so (numbers are for demonstration purposes only). So, don't be suprised if it overheats again until you put a new t-stat in there.
Also, another question was the coolant really rusty? I have seen the impeller fins on water pumops get rusted or even worn down if the WPis really old. At idle it turns really slow and it barely pumps. If your system was not all that rusty though it's probably ok.
