ricers1 wrote:its bad compression. cyl. 1 was 145, 2 135, 3 130, and 4 45. at this point im just going to take stuff apart and do a rebuild on the whole motor
Pushing the stock CA at W.O.T. too long with stock fuel management system and increased boost pressures and possibly having your car not timed correctly will almost always results in a melted piston on the intake side of the piston aka "DETONATION" . A smart kid would pull the engine out of the car and inspect all four pistons because you may have cracked them all (it don't take much). No more questions, just take it apart and let us know what you find because clearly something is wrong. Good luck.......
Dee
